Team Banana
- Aug 9, 2008
Tube steak ftwRonnie don't lie, you'd get the tube steak
SignUp Now!Tube steak ftwRonnie don't lie, you'd get the tube steak
I thought norbs did it. I will look at his threadI don't care how the rules votes go for you guys (although, I will be offering special THS pricing for those who want a hood), but have any of you ever put a distributor in a car with AC? As far as I know, only Tony Gomes has done it, and it required quite a bit of grinding and welding.
http://www.turbobuick.com/forums/threads/time-to-go-stage-ii-with-a-c.380569/page-4I don't care how the rules votes go for you guys (although, I will be offering special THS pricing for those who want a hood), but have any of you ever put a distributor in a car with AC? As far as I know, only Tony Gomes has done it, and it required quite a bit of grinding and welding.
rewriting the rules to add more weight to iron heads is dumb....you should knock off 50lbs on alum. why would you add weight to add more wear and tear on cars when you are trying to grow the class....
by changing the rule in your direction only eliminates people... by lowering weight it helps increase car count ....
my .02.... of which i am sure everyone will go against since I am me...
Thanks Kevin I'm not going to even try. Not worth it time or $$. Good luck to all.
Ya thats why racing is a dieing sport. It's a rich man's game.
That is like dirt track racing boring but that is where the money is. We don't do it for the $$Could always turn it into an index race!
You should take the 50lbs off the Alum cars if you are trying to get the class closer together....
IF you are trying to eliminate a particular Iron headed car that has the fastest time... then continue down the path of undermining individuals....
Why even change the rules at all?... why is there not a vote for not changing the rules at all? These are rhetorical questions.... as I already know the answers with the spin put on it....
Ridiculous!
Only thing I'm pushing for is the damn 400 !
S = SLOW[/quote
Glad you clarified that
Figured it was S for South or something
