I have a stock GN rear end with the G-80 option. I believe I still have the original 28-spline axles. I have an axle seal that is leaking (even after installing a new one). I suspect that my driver's side axle may be grooved where it rides on the bearing, so I'm considering a new set of axles. Are any other mods required if I end up having to replace axles and bump up to 30-spline axles? Seems like I'd have to change out something inside the pumpkin to make the 30's fit.
I can't imagine I could just pull out 28-spline axles and throw a set of 30-splines in. Seems like I might have to re-do the whole thing.
