How do you keep the sender seal intact if you run a wire through the top of it? Rubber grommets and/or sealant will not work. The bulkhead connector assembly is certified pressure tested. Our G7x-BCA has upgraded wiring which runs from the sender connector to the new bulkhead connector.
Says you.
Good sales pitch.
