Thats what I thought too. Thanks Davethought the separator plate had a difference for it too?
maybe not anymore
I answered how to do the mod in the valve body. Maybe I overlooked what was really being asked. Yes, if you use this 3-2 control mod, you should be dual feeding the direct clutch. There are mods that need to be done to the separator plate for proper shift timing depending on the servo being used. Sometimes the 3-2 control mod needs to be removed for proper shift timing. There is a lot more to it then a modified plate and a valve being locked open for this to function correctly.thought the separator plate had a difference for it too?
maybe not anymore
And no body wanted to answer that question. Hmmmmmmmmmmmmmm.So this is only if dual feeding the directs?
Reason I ask....PTS early design servo(they where all made by Richard Clark) had an issue. I have one and when I told RC he said bring it to him and he trimed the piston a bit, maybe worth looking into mine was doing wierd stuff. Its still on my bench so I cant comment on how it works now.It's all PTS stuff, servo isn't purple. Only 6-7k miles on it.
