3.8 litre hot air blown engine
jumpinjosh
I have a 1985 hot air 3.8 litre with a blown engine. Will a hot air turbo engine from a 1981 swap out for the short block with my engine. That engine has a carb and distributor. Mine has ignition pack and throttle body. I want to know if my top end --manifold and ignition pack will work with the 1981 short block.
You will have to use the oil pan, timing cover off the early engine as the 85 should be a 20 bolt oil pan and the 81 is a 14 bolt.
I was thinking that some of the early production 85's still had the 14 bolt pan. Maybe I'm wrong..
That very well could be. Both my 85s were Oct. 84 cars and were 20 bolt blocks. : )
