anyone using a 3 bar map with a fast ? Mine seems to be a little off. On the laptop it is showing 26 - 27 lbs. of boost but my boost gauge and fuel press. gauge says 22lbs. Which one sould i belive? Anybody else seen this differance?
I'd suspect the MAP, being close to it's maximum reading, is the inaccurate reading. A 3-bar MAP's maximum reading *should* theoretically be 29.4#, but all units will have some production "slop" tolerancing and may not be as accurate when close to the limits...
1 Bar = 28" vacuum to 0# pressure
2 Bar = 28" vacuum to 14.7# pressure
3 Bar = 28" vacuum to 29.4# pressure
As you can see, the more the "bar", the less resolution is available for a 0V - 5V signal, which is prolly making your MAP reading skewed a little.
You can check it against an air source but I would bet you will find the MAP to be much closer.
Remember the FAST unit makes all of its calculations off of that MAP sensor so that is the one to trust.
My Dads GN had a manifold with 5 or 6 leaks in it. It took us forever to figure out what was going on. The boost gauge would read 30 psi but the MAP was only reading 24 or 25.
That's all that counts.
That and remembering you tune to keep the motor happy, not tune to get a number. Just cause someone else runs 7s with 32 PSI at a 11.2 AFR means that your car will be fast with that tune.
Your's stand a 50/50 chance of wanting less, or 50/50 chance of wanting more, from anything anyone else reports. Don't fall prey to the numbers games. They are just some hints on what MIGHT work or even be true.
