87turbot-type
wo2
- Sep 2, 2007
Just making sure this is correct.
I already have a 3 bar map sensor installed for my SD chip. I am planning on buying an alky kit. Do I need another map sensor? I should be able to just use that signal for the alky as well?
Also I am running 20psi on a 6131 and trapping at 123mph on straight pump gas. I plan on running around 28-30psi with this turbo and alky. Would you suggest running the dual nozzle with this amount of boost?
Thanks Brandon.
Thanks Brandon.
