SignUp Now!Yup.. must have the decals on them.
You can also tell the China ones becuase the have a dark orange insert where the weather pack plugs in.
I sell the correct sensors for 70 each. They have the 12223861 on them.
If your using it for datalogging where its not critical.. who cares if it fails. Buy a cheapo chinese one. If your using it for alcohol injection or engine management.. it is not the place to skimp on quality.
Looks like a perfect example of the China sensor with a RACETRONIX sticker... Which is fine with me because you are not trying to pass it off as the GM sensor. At least we can buy them from a vendor on this site instead of import vendors on Ebay.
How can this type of sensor be tested to see if it's good or not? Usually I know one end is negative and the other end is positive going into the sensor and the center one usually puts out up to 5 volts I guess to whatever it's input would be in this case boost or positive air pressure from the manifold. Would this be a accurate assumption How much positive air flow input would equal maximum electrical output I guess 5 volts? 30-45 psi boost?
