30 Spline Eaton Posi clutch kit
ttypewhite
Who has any links on where I can get one? My clutches are toast. This is for a stock rear end.
Thanks Paul. I'm sure there will be several interested in the parts since they seem to be so hard to find.:cool:
I talked to a rep today about that and he said it is a much more aggressive kit and will give the clutches more life, but it comes with a trade off. You will get chatter during turns. My car has every driving characteristic of a stock Buick. I can't stand noise of any kind that was not there from the factory, so I will be bypassing that.:redface:
Quick question for my own curiosity....You said you needed 30 spline clutch kit ans then you say its for a stock rear. Stock rear had 28 splines. Are you running a 30 spline unit in your stock housing. Is that what you mean by stock rear? Only reason im asking is because Ive been looking for a replacement clutch pack (28) for the stock LSD for months with no luck. Let me know what you find out. Thanks
I think all the parts from Summit are for aftermarket eaton posi carrier's not the stock G80's but i caught that also!
Chris
