vacuum 6
- Jan 6, 2006
As for strength and materials. The bezel above is made from black ABS. There is a wide range of materials from simple to complex. As for strength, these parts can be very strong by design and simply by the material choice. High temp, high strength materials can be used as well and I'm pretty sure they have been in the airplanes most of you fly on as end use parts!
Unpack the definition of high strength. The X and Y directions are strong. However if the printer doesn't weave the Z....not so strong unless we are talking compression. Orientation of part is critical when printing.
