jason mizel New Member Joined Nov 20, 2007 Oct 6, 2018 #1 Hi I am putting together 291 block, anyone have these items? Otherwise I might modify the stock oil pan by adding the baffle plate the 3.8 pan has...
F Fat Nat Well-Known Member Joined May 25, 2001 Oct 7, 2018 #2 jason mizel said: Hi I am putting together 291 block, anyone have these items? Otherwise I might modify the stock oil pan by adding the baffle plate the 3.8 pan has... Click to expand... 150.00. Really nice custom pan
jason mizel New Member Joined Nov 20, 2007 Oct 8, 2018 #3 Cool u know what the capacity increase would be if I were to run that? Also what pickup tube would be required...
jason mizel New Member Joined Nov 20, 2007 Oct 8, 2018 #4 Just seen it's for a 20bolt block won't work I've got 14
E earlbrown runs with scissors Joined May 26, 2001 Oct 10, 2018 #6 jason mizel said: I might modify the stock oil pan by adding the baffle plate the 3.8 pan has... Click to expand... That's actually pretty easy. I build mine out of a Sony VCR case. https://www.turbobuicks.com/forums/buick-v6-turbo-tech/88129-day-life-earl-2.html#post788883 ...you can see the ''Y'' in 'sony'..
