Aug 3, 2007 #181 R RUQWKNF27 Active Member Joined Apr 3, 2003 Messages 1,892 Now if I could only get it to start fueling under boost I could stay into the throttle and see what happens. ARRRGH! So almost like fuel can't keep up with the air flow! Are you showing any knock when you get on it or go WOT?
Aug 3, 2007 #182 T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Messages 10,084 TurboBob said: depends on the car. A car slower than 12.0 will pick up a little power. faster cars will realize a larger difference. Spoolup is enhanced some on the larger turbos (I have a 6776RSH, a bit big) Bob Click to expand... Hey Bob, are you using the 4' maf pipe with the Tpro? I would like to try this.
Aug 3, 2007 #183 B Blazer406 Mechanical Engineer Joined May 2, 2002 Messages 5,068 Rick87GN said: Hey Bob, are you using the 4' maf pipe with the Tpro? I would like to try this. Click to expand... I was thinking that one of the benifits for the TPro is you didn't run a MAF.... it was speed density.... Maybe you can do either?
Aug 3, 2007 #184 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,679 I have run it. But I usually run speed density. The Pro can run as a translator if you want, thats one of its built in modes. The Pro software has not been updated with the 6.25 version stuff, but could be. Bob
