turbobitt
- Feb 14, 2002
I have Aerospace brakes pro-street brakes front and rear on my car. I converted over to manual at the same time and in process of working out the brake pedal geometry and master cylinder size to get me the brake feel I'm looking for. So far I have the 1 1/8 master and the pedal is set up to an exact 7:1 ratio. The pedal feel is tolerable but could be better and plan on switching over to a 1 1/32 bore cylinder.
The master cylinder is plumbed per the instructions with the rear port going to the rear, and front port going towards the front brakes for drag race applications.
If I hit the brakes hard it will lock the rear brakes. I been debating on putting an adjustable valve in-line to the rear brakes. Now maybe I'm overcomplicating this and looking to deep into the set-up but knowing how the master cylinder operates seems to conflict with some of logic of using an adjustable proportioning valve. The rear most port on the master cylinder is really provides positive displacement of fluid because it has a direct link to the pedal while the front port has a piston that provides pressure through a set of springs between the front and rear pistons. This leads me to believe that the front port is not a positive displacement port and can/will vary the output based on fluid pressure/resistance. This has me thinking if the adjustable valve will really work on the rear port ??
Am I just overthinking this or should I swap the lines around before adding the adjustable valve ?
AG.
AG.
