Exactly. Its doing what its supposed to do. I'm not a fan of running it on that edge of knock like your doing. Bet if you leaned out the afr into the 11's it would knock way worse.Here is a good example of how engine temperature affects my car. This was an extended run in overdrive to really load the motor Coolant temp was 188 and outside temp was about 90. After this run in these conditions I knew the dyno pull would be ok in 3rd. Not pretty but at least I know everything is working. I also pulled fuel after this to clean it up a little.View attachment 204749
