Buick Mark
- Sep 12, 2001
WOW that IS impressive!
SignUp Now!TPS @ wot is low
keep in mind that you will generally get a lower number on a Mustang dyno. Of course most everyone likes the higher Dynojet number, including me!
Run it rich.. low 10's for AFR, run low timing 18 degree's, run it on a dyne(short pull.. few seconds).. I can see it.
Now run it down a track for 12 seconds at 23 psi, afr in the mid 11's, and show me the log.. I'd also be suspect of the knock sensor not picking up any amount of knock. Like if it wasnt tq'd down properly or disconnected. I usually have better belief when I see a little transitional .5 degree somewhere.
This is why I hate dyno's. They can give you a false sense of things on these cars.
60lb injectors?
That is some serious power running nothing but gas and through cat and the like.
Looks like a bunch of internal work done.
That is one nice running motor.
I've been curious to see what the best stock tune can be with stock internals, injectors and the like? I guess all but stock chip and adjustable boost.
That is some monster boost with no knock and nothing but 93.
Great post,
Joel
Very nice Mike! How far you going to take that 70gtq?
yes I was thinking that's a big turbo for the combo ... I have a 70gtq on my tta
nice #'s on 93 without alky
It's rod. Let me outUSER WARNING.....Preceeding further may results in a knock knock whos there joke
