Scott,
I don't agree with the rationale that 900ft/lbs is the limit. No proof, but a stock Duramax only makes 520 ft./lbs of torque. Of course GM would change transmissions for a newly packaged truck..... I'm sure that the allison, since it has more gears, is more suited to towing, longevity, and keeping the diesel in the correct RPM range.
As for the 4th gearing, I actually find it much more pleasant than the 2004r. The engine is up a hundred or so RPMS and takes itself out of the drone-ing zone on the highway. I wouldn't see any other reason for a steeper fourth gear except for 200mph cruising. If you want that, put a 2.73 gear in the back and go on.
Stage274, I'm currently using an advanced adapters plate and it works well and is nicely made (thick). My transmission guy has actually gone to the length of welding new bosses on his transmission for a direct pontiac fit.
Transmissions are such a "touchy" subject, I'd advise anyone against the 4l80e to get off this post right now and let the guys who are interested continue the post. Everyone, including myself is going to think their opinion counts.
Thanks,
John
