Why is it "impossible with that setup??" I believe you've got alot left! Think.!!
32psi in the intake IS still 32psi... All you're going to gain by your exhaust fix is more flow to support a bigger turbo, more boost(not likely to make a difference with the 76gtq), and the possible bonus of quicker spool time. I doubt the HP change will be signifigant. My primaries are 1 1/2 and my crossover is 1 3/4 so I'm curious to see if your theory works out. BTW, I'm still running a 3 bolt 70 series with a stock wastegate at the same psi, same weight, no alky, no liquid IC or carbon fiber intake, and the same results! Not trying to take anything away from your results but....WTF???? I've got "some left" and I believe you do too with some fine tuning. You've got at least 5.40's with that combo! Good luck.
Foot brake-No N2O- Irwindale
YouTube - 5.78@128 Fastest Toyota Street Truck
Scott Wile
The intake I made is not carbon fiber. It's hammered out sheet aluminum. The upper part, anyway. I'll take that as a compliment though. Thanks.
When I was first putting the engine together, there was a lot of the normal speculation that goes on. Here's a list:
M&A heads. They're junk. They leak. The flow is just a little better than stock heads. Takes too much work to install the valve sizes you really need.
I'm still running the original 1.835 intake and 1.5 exhaust.
The camshaft. Too much duration. Too much lift. The lobe separation is too tight. There's too much overlap. You don't need to rev a turbo motor that high.
Cubic inch displacement. You should have stroked it to get more cubic inches. Instead, I destroked it. 3.06.
Exhaust. The primary tubing diameters are too big. 1.625" stepped to 1.750". The collector sizes are too big. 2.250". There's too much volume in the exhaust system. "Long tube headers don't work on turbo motors."
Intake. You need longer intake runners. The plenum volume is too much. You don't need that big throttle body.
Turbo. The best you can do with a T76 is 9.20s. Turbonetics T76 is old school. Outdated.
Nitrous. You're just going to blow it up. I've blown 2 engines in 7 years. The reasons for each had nothing to do with the use of nitrous.
Milodon geardrive. You'll transfer harmonics to the valvetrain and bust things up. They're noisy. I dare anyone to try and tell if I'm using a geardrive by listening to the engine. If someone ends up with a noisy Milodon on a Buick V6, don't blame the gearset.
Torque converter stall. 2400 rpm @ 0 boost. The stall is too low. Slippage is too much on the top end. Neal Chance converters don't work.
Methanol. Why are you running methanol? It corrodes. It blows engines up. You need to run 2 electronic injectors per runner. You need to run mechanical alcohol injection.
Turbo 400 trans. They eat up horsepower. You'll lose 2 tenths or more. Really? Can I add that onto the ET I'm doing then?
Driveshaft. Diameter's too large. Weights too much.
Rearend. You should be running a 9 inch. 12 bolts are weak.
Tires. You need more tire. Well, I won't argue that one.
Electomotive TEC3r. They're junk. Too hard to tune. Confusing. Hurts my brain. Mmsh, mmsh, mmsh, momma.
Everything about my setup is wrong. Yet...
