SignUp Now!All very good points. Good food for thought. Thanks. I talked to Precision today, and they were torn between the .96 and 1.08. Much the same way I was. Pete swayed more toward the .96 with the T6 housing. He felt that if the .96 a/r did end up being too small, at least you can race with it until the next housing comes in. He saw the only benefit of sticking with a T4 housing being the ease of installation. He was pretty sure the T4 housing would pinch off a little power on the top end. I don't want anything being pinched off. I'm more concerned with getting the right setup for top end power than making it more convenient on me. If the best setup is the T6, then I'll make it fit. Another thing. As soon as I mentioned I was using a 200 shop of nitrous to spool, he didn't hesitate to recommend the T6 housing.
I don't but Dusty does, a friend of his has one on a V8.
You may want to hit up Jose at forecedinductions on the BW stuff.
He seems to be the most knowledgeable person I know of with them.
I'll make sure to take pictures. I'll probably post them on our website.
With all these monstrous bp guesses, I'm starting to think I should swap on the .96 housing I have sitting around for the T76 when I go back together with this leak repair. What do you guys think? Would it be worth a try? What would you guess the bp drop would be with the larger housing? How much hp might there be? The turbine wheel is the old Turbonetics Q trim.
Yeah, that procedure still needs to be figured out. Because of the timer that I use with the nitrous system, I'll have to race in the electronics brackets. In some cases that bracket uses a .4 Pro Light. I'm going to have to go WOT as soon as I stage and wait on the starter to bring the tree down. The nitrous will get the turbo up very quickly. Not too worried about that. The thing that worries me is, how will I keep the boost level reasonable for the launch with a 200 shot nitrous system trying to get it up to 16 psi? With the tires I'm using, a 16 psi launch is too much. I suppose I'll have to start playing with the launch and boost rise features of my electronic boost controller. Launch procedure for a pro light will be one of the last hurdles for me.
I've got a CO2 bottle, but I've been resisting setting it up until I really need it. I understand what you're saying.
Big surprise today. I started taking the front of the engine apart to fix a nagging leak. When I pulled the Y pipe that feeds the turbo off, I looked down the side that has a bellows in it. That's the side fed by the left bank. The stainless braided wire mesh inside the bellows has swelled and partially blocked the pipe so that the passage through it is just over 7/8 inch. Ya think I might be losing some power there? The bellows is going bye bye and I'm replacing it with a straight pipe.
Imagine this. You've just done a best with the car that most would swear was impossible with the setup you're using. You decide to do some maintenance and you find this.
