SignUp Now!It has been done twice that I know of. Once by a car mag and another is in a1st gen Nova. I can be done but you would be much wiser to use a Series II engine to do it. Much better block and heads than stock and you can get adapters so you can run just about any type of tranny you want in it, whether it's a BOPC pattern or even (God forgive) a ferd tranny.![]()
If you are going to do this, its better to start with an engine that rev's higher or it will be like driving a Diesel that makes no torque below 2400 RPM.
A 2500 RPM power band is pretty small for a manual transmission car.
it would make for one hell of a fun car if a guy could figure out how to maintain boost when shifting.. how do they do it in every other turbocharged car in the world that's available with a manual trans?
I am still sitting on my flywheel and clutch pedals for this modification.
As it was pointed out using the Series II engine is a better idea as the thrust bearing isn't as big a potential issue as it is with the LC2. Not that Buick didn't ever mount a stick behind it's 3.8L V6.
Also BOVs don't work on Turbo Buicks, you can't fit a 315mm tire without a frame notch and they can't be auto-x/made to handle.![]()
the question was about a Tremac 5 speed trans.. so either a TKO 500 or TKO 600.. i think the general consensus is that a manual trans didn't work behind the TR engine 20 years ago, so it can't be done today..
Simple, just don't let the throttle close. The throttle closes and the blow off valve bleeds off the boost so it doesn't shock the compressor. If you keep the pedal on the floor you won't loose boost.
Not that its really a problem to loose boost between gears. Think about it, you wind out 1st gear, shift at 6,000 RPM. Now you loose boost but when you shift into second you are around 5,500 RPM and you will build boost just about instantly at 5,500 RPM. Its not a real problem. In my mind anyway.
Good idea but that's not exactly how it works. If you route the BOV back in front of the throttle when the turbo "sneezes" it keeps the compressor wheel from trying to spin backwards. It really will do that when the engine RPM drops off, and if you use a light weight flywheel the RPM will really drop off fast.![]()
