Galina/Freeman went 200 mph I believe but that was a TT.
Super to see you getting a handle on the tuneup, Mike. Lots of passes and no breakage that I heard about. Sure was fun to watch!
Thanks!! The first pass ended at about 300' with a big boom (burst panel) and I was more than discussted!! After downloading the racepac info I only had 11 pounds of fuel pressure. Found that the 3-way valve at fuel pump was 1/2 open. This was caused by the cable bracket that controls it was bent out of adjustment. Checked out the engine and everything seemed OK with it so we started very slowly with a very rich tuneup and kept leaning on it a bit more every pass. Ended up making 7 passes. On the 6 pass the parachute popped out of the bag at about 300' and opened up about 500', which scared me as I thought that I must have spun a bearing because it sounded good but suddenly nosed over. That problem ended up being that the aluminum plate inside the bag bent backwards, which shortened up the cable and pulled it out of the loop. I need to permanetly fix both items.
If the chute hadnt come out on the 6 run that would have been that 6.92 and we could have tuned it up from there. Im confident that it would have went 6.82 if I would have made another pass. All in all it was a great weekend for us as I also was driving Jim Rocks car and we got it in the 7.90's
BIG THANKS to the BPG for inviting us!! We had a wonderfull time and were treated very well!! Special thanks to Sean!! Mike![]()
Damn Mike even a broken clock can be right at least ONCE per day...:biggrin: Why you bragging so much?? LOL!!
Ok if that came across as bragging Im sorry!! I was accussed of sand bagging so many times that Im gun shy!! The first run against Rod when it went the 7.07 was the first EVER run that it has made it to the 1/4 mile finish line under full power. And I was scared to death that it wouldnt make it. After looking at that data I made a few small adjustments for the next day. Conditions were much worse on Sunday and it still picked up over a tenth of a second. Easy to see from the data that there was more in it , and thats where that bragging came from. Good to hear from you Clint!! Are you going to make Bowling Green?? Looking forward to seeing you there!! Mike
Mike that was an awesome run! I was helping Rod and Danie and really was impressed with your car! The pass against Rod's car on the starting line was simply awesome with the RPMS maxing out! Hope to see you at BG and come back to Columbus next year! You really drove Rocks car well as normally that thing skates all over the lanes! A job well done!![]()
hey mike...7's on Jims or your rail....also thanks for the kind words as you know the BPG does its best to make sure that everyone is happy and welcome...I would do it all again next week,,,,,if my wife would let me lol...
well as I told you...there are some changes coming...the frantic four seems to be the way to go...new class...Buick Powered...no Buick body...that will open up the field...again really glad you got your best run/s at BPG and will try to get a bigger pot in 2011...again you are more than welcome at BPG events...glad you had fun as that is what it is really about,,,![]()
I would like to try and compete just to have fun and smack JD around a little..![]()
