Parker makes them in steel. I wouldn't trust an aluminum one myself.
Here is one source for a -4 x -4 female/female union if that's what you are looking for. I usually use a TEE one or fue pressure gauge and one for fuel drain at the rail.
6565-04-04 | FEMALE JIC SWIVEL x FEMALE JIC SWIVEL ADAPTOR
Check with a local hydraulic supply shop in your area. JIC is the same as AN (37* flare) Hydraulic fittings are MUCH cheaper than pretty blue/red AN fittings, but are MUCH stronger. (though much heavier, too.) If it's under the car or used on the fuel system I tend to use the cheaper JIC stuff. Out in the open on a nice car I'll use AN (Earl's. Russel, Areoquip) You can also get the JIC in stainless steel, too.
