600 horses
freakazoid
Is 600 hp possible with ported iron heads, 83 lbs injectors, 62 mm throttle body, alcohol injection, 218 cam, precision in front intercooler, large turbo, 3 inch downpipe, 3 inch straight pipe, hot wired. 93 octane fuel. Tranny has been massaged. does anyone has a 600 hp combo?
You have all the right stuff to make the hp you want.
Tuning will be the key using both gas and alky.
Why 600....? do you have a dyno bet. Question you need to answer is.....How fast do you want to go.
Bryan I've seen 600 on the ground and I must say it aint pretty.
Evidently this is not your motor. What size did he say his turbo was? Nevermind. Combination, combination, combination x seat time.
Large.......:D
th
Takes a 10,000 RPM stall to spool the thing though.
Read my threads in the time slip and combo database. Based on your signature and post id estimate mid 11's and 450hp at best.
