1KWIKSIX
- Sep 29, 2007
SignUp Now!They are indeed off the shelf Champion cnc ported irons. rear wheel should be about 20% lessI’m assuming this is not on off the shelf cnc champion irons. What did it make at the wheels?
They are indeed off the shelf cnc ported Champion Irons. 527 RWHPI’m assuming this is not on off the shelf cnc champion irons. What did it make at the wheels?
Unsure. I'm guessing a 95 deg.day vs a 59 deg. ISA day.Why is the weather correction factor so drastically different ?
93 and alkyWas this race gas or e85? Nice numbers.
Absolutely.... more pressure, bigger bangNice number!
Higher compression does wonders...
FWHP (Mustang Dyno Calculations)..... with WCF number represents RWHP. Bison spec'd cam and turbo, easy 10 second powerfwhp or rwhp ?
Correct... Here is the main problem when people post up pics or vids of dyno numbers. They all read a lil different. Dynojet can be posted as corrected AND uncorrected, with that people are going to post which ever make the most power to the masses. If you took your car to one dyno and it shows 545 at the wheels, then to another that shows 600 at the wheels, what do you tell anyone that ask what power did it make??
The answer is obvious......
The LEAST amount.![]()
Whoops .020 over!Bored .002 over?
Didn't even know they did that.
That was funny and actually a very good answer at the same time. Most wouldn't have the self-control to pick the lower number.
