1985 engine 20 bolt oil pan. .30 over speed pro pistons. 10/10 crank. rods resized with arp 2000 bolts . t/a coated groved cam bearings. t/a oil pump hv caspers cam sensor cap led type. comp cam and lifters stock replacement 200 200 duration .403 .403 lift . fel pro 1000 head gaskets arp head bolts manley exhaust valves new springs p/c seals installed runs great 500 miles since rebuild went to v8 turbo so must go 1500.00 obo also has new water pump, timing chain
200r4 BQ trans fully rebuilt shifts great one of the best i have had 500 miles since rebuild , went v8 turbo so has to go
scanmaster 180.00
86/87 headers and crossover 80.00
stock intercooler and shroud 80.00 have 2
vac brake set up includes master pedal booster 120.00
complete non a/c set up heater box comes with everything to delete a/c cables ducting box needs glovebox door and blower motor 140.00
86/87 intake fuel rail upper doghouse 200.00
36 # injectors set of 6 85.00
scanmaster 180.00
