87 gn t top car
75000 miles
From Orlando
249" motor
6.350 k1 rods, upgrade arp bolts
3.625 forged crank
rjc girdle
rjc deep pan
ta front cover
bhj balacer
mls head gaskets
arp head studs
champion aluminum heads '' new style''
td shaft roller rockers
champion race intake
70mm t body
rjc xtf 315 front mount
ta stainless headers
ta stainless 3.5 ext gate downpipe
precision wastegate
fast xfi 2.0 from Cal, four tunes on thumbwheel
custom harness from caspers
stock ignition
msd pro coil
msd distributor setup
dead end plug to use msd
msd 7al for 6 cylinder
stage 3 extreme 2004r with brake, deep art carr pan
ptc 9.5 ''17''
bm big trans cooler
10'' fan for cooler
black braided trans lines
3.5'' dynotech driveshaft, 1350 joints
8.5 rear, ta girdle and studs
strange 33 spline spool and axle package, with timken tapered bearings in eliminators
weldon 2035
weldon dial a flow
weldon regulator
120lb injectors
rhodes black wrinkled 15 gallon cell, -12 out, with gm sender
trick chassis dbl adj chromoly uppersand lowers w/ teflon lined rod ends
trick chassis instant center upper buckets
hr sway bar
qa1 coil over springs
wolfe adj spring perches
trz front pro series uppr and lwr control arms
first gen f body spindles
billet aluminum steering arms
billet bump steer kit
strange front and rear pro steel drag brakes, with black calipers
trz billet master cyl mount
strange manual master
s10 manual steering box
hartline glass hood
hartline glass bmper
tnt aluminum bmpr supports
qa1 pro coil over setup with 350lb springs
has bell tech spindles also on the stock control arms
autometer ultra lite guages
kirkey pro drag seats with black tweed covers
tr custom parts kirkey mounts
tr custom firewall plate with buick motorsports logo
I am sure there is a ton I am forgetting, please call if you are interested. Car has real nice paint. I have a ortune into this package, before I part it out I wil offer it as a partial build package. most of evrything is new. Please call to get more specific details. Price is pretty solid, 25,000.00 title is clean ready to go.
815 342 8509
nospirated@yahoo.com
I can send as many pics as you need just call, if I dont answer please leave voicemail.
this is a nice car, it is under unfortunate circumstances that I have to sell it.
75000 miles
From Orlando
249" motor
3.625 forged crank
rjc girdle
rjc deep pan
ta front cover
bhj balacer
mls head gaskets
arp head studs
70mm t body
precision wastegate
stock ignition
msd pro coil
ptc 9.5 ''17''
bm big trans cooler
10'' fan for cooler
weldon 2035
weldon dial a flow
weldon regulator
120lb injectors
hr sway bar
hartline glass hood
815 342 8509
