I understand that it's tempting to look at the alcohol as the reason that the bp is so low. I tend to think it has a lot more to do with the massive turbine housing and the 110/100mm
turbine wheel.
When I was running the old T76 with the .92 a/r, Q trim, the bp ratio was 1.5-1.6:1. Since data on that turbo is more readily available, maybe someone can let us know if that exhbckp/intbstp ratio is unordinarily better than what is usually encountered. If it's the same as what others have seen with gas applications, then maybe the alcohol isn't making that big of a difference.
