AC compressor gasket.
stagemonster
R.C. entourage
dose anybody have a part number for the ac compressor rubber gasket that goes on the back of the compressor where the 2 lines connect. I could not find it on advanced web site. Any help would be great thanks in advance.
It's been a while since I replaced mine but I think it's 2 seperate gaskets one for each line. the Help section at vatozone should have a set
Its one gasket and the 2 lines go into a one piece with a bolt goes thru the center of it
It's two o-rings. They are available in the generic a/c o-ring kit available at any auto parts store. Most will have some in their backrooms if not on display.
pay attention, as some compressors require a thicker oring/ gasket.
some use a metal/rubber type, you need to measure the depth of the back of the compressor.
and buy accordingly, i found them at NAPA
