Chris McDade
- Jul 13, 2001
Does anyone know where I can get a Delco Ignition Module? I want Delco not BW.
Thanks in advance.
Thanks in advance.
SignUp Now!I've got a couple stashed away. It's the one with the tan colored epoxy not black like the newer (junker) Delco's. Part # 24503624. Same one HighwayStars sell for $279. Might be willing to let one go. PM me if interested.Does anyone know where I can get a Delco Ignition Module? I want Delco not BW.
Thanks in advance.
Do you run more than stock boost levels?I know you said you want a Delco but as an alternative you can use standard motor products lx338 it works like a charm. I had a magna vox unit which did not run my aftermarket tach, it still worked well but the lx338 is perfect. It's been on the car for years and no issues.
22-24 psi and meth on 94 octane and a tightly gapped ngkur5 plug at .028Do you run more than stock boost levels?
This is the one that I have. Seems to work ok so far. Got it from Rock Auto. At the time there were no AC Delco ones available. Next year I will crank up the boost and see how it works.I know you said you want a Delco but as an alternative you can use standard motor products lx338 it works like a charm. I had a magna vox unit which did not run my aftermarket tach, it still worked well but the lx338 is perfect. It's been on the car for years and no issues.
Did you ever install that module, if so how'd it work out?Here are pictures of the module I received from Rock Auto.
