I had my AC converted from R12 to R134a today. But the LP was way too high - 150-200 psi. HP was 130-200 psi and should be OK.
We followed the procedure explained at the GNTtype.org, but the pressure-cycling switch acted a little odd. The procedure says:"You can reduce the cycling pressure by turning the screw beneath the connector on the cycling switch counter clockwise." When doing this the cycling pressure raised. Turning the screw clockwise reduced the cycling pressure. The compressor went on and off every 4 second.
Fan worked OK and I got cool air inside the car.
I have a new compressor, orifice valve and pressure cycling switch.
Could anyone help me, please, and explain why the LP is that high ??
Per B.O
Per B.O
