Accel Gen 7
chris
Bought this off of another board member, (KevinB) but never got around to installing. He ran this in TSM and THS into the 9's. Tune in the box is set for 96 lb injectors.
What you will get:
-Gen7 dfi box
-External data logger and wideband controller
-adapter harness for a factory buick harness. Wires are long enough to put system under the pass seat
-usb pro key
-3 bar map sensor
-extra pins for additional wiring
-user manual, software and other info can be downloaded from Accel site
-full size wiring diagram
Things this ecm setup can do:
-data log without having a pc in the car
-great nitrous controller
-handle 160lb injectors
-get rid of maf sensor
-wideband correction
It will control ac components and overdrive transmission.
You'll need to purchase new WB O2 sensor.
$850
I am interested in the USB Pro key, if you decide to sell separately.
