achalmersman
- May 28, 2012
Well, I'm progressing on this again. I have the crank, rods, pistons, bearings. The cam and rings are on their way. Today I worked on clearancing the #1 rod to oil gally tube. I layed the crank in the block and hung one slug and rod to the number 1 journal. Snuck up on the grinding until I could sneak a 0.030" torch nozzle cleaner through the gap. While that rod was hung I measured my rod side clearance to be 0.006" and the rod small end to piston clearance at 0.017". After machining the rods for the better clearance in the neighborhood of 0.010-0.012" my little end to piston clearance should open up as well. Next will be clearances to the cam once the camshaft gets here. After that the rotating assembly will go to the machine shop to have the rods milled, and the assembly balanced. Pictures included
Sent from my VS990 using Tapatalk
