Don, your my idol.
I have to explain something so I don't confuse everyone. I'm using an Electromotive TEC3r EMS. Unfortunately, the graphing feature is lacking with that system. I use the Motec software only to check my tables using their excellent graphing features. I just plug my numbers into their program and examine the table with much better clarity and view angle choices. I know that some people ignore the graphing feature of their software, but I've gotten very used to using it to gain more insight into what the engine wants. It's like looking directly into the soul of the engine. I think Motec understands that very well and that's why their graphing is so superior to others.Donnie,
How frequently does the MOTEC adjust the engine parameters? I know that FAST XFI is much faster than the old FAST software. Could you benefit from a quicker refresh rate?
Conrad
Thanks for the narration on the logs. Very interesting stuff to review.![]()
Are you not using O2 correction because of the time it takes to correct or are you just that good??I always leave positive correction on just in case there's pump problems.
Scott Wile
No No No..... My correction. I'm talking "upper" VE/boost (35-40psi) That turbo will laugh at 24psi:biggrin: My guess is that you'll HAVE to run a certain amount of N2O throughout the entire run to maintain exhaust energy..
Scott Wile
You're brave!
Scott Wile
If anyone has any questions, fire away.
Ok, I can't read the time cursor, so is this close? RPM approx 2400ish with the N20 off - T-brake on. N20 on and RPM 5500-6000ish. T-brake still on? I guess my question would be does the N20 raise the stall speed of the converter , or is the RPM rise off the T-brake?![]()
