six shooter
Quiet Member
- May 26, 2001
Do you think this new combo would be happier with more mechanical compression ratio ?
Yeah. It would certainly help off boost and to spool the turbo. But, the low CR does a good job of keeping me out of trouble.Do you think this new combo would be happier with more mechanical compression ratio ?
I've already determined from the last time out with the car that once the car is on boost it can maintain it without the nitrous. At least, that goes for the last tested target boost of 260 kPa (24 psi). In fact, the boost rose very sharply in first gear to well over target boost to just over 300 kPa without any sign of nosing over before the controls brought it back sharply to target level. It was nice to not see any dropping of the boost level during the duration of the run for once. There was a short spike on the 2-3 shift. If the testing tonight shows that the mixture has room, I'll be stepping up the boost target. 2 psi steps. Watching the fueling level. I still have the wall and the upper right region of the fuel map to dial in. The fuel pump booster is at 42% now. If it looks like I'm running out of fueling after the booster is maxed to 50%, it'll be time to figure out a new injector nozzle size for the aux fueling. I'm confident the existing nozzles will take me to at least 32 psi.After some testing tonight I'm pretty sure you will need a sizeable amount of "exhaust energy" (n2o) to maintain the targeted boost level, unless my tune is WAY off or alcohol makes that much more power. :redface: I hope you have better success than me Don!( i'm sure you will)
scott wile
Yes Lee, it was a very stimulating experience. It is the only thing I have to justify the turbo change at this moment. If I didn't have that, I think I'd be disappointed.
In the cool air I can run a 1.32 a/r on my 94mm but when the summer heat got here I could not get enough launch boost. I was at 4# in the cool air and 1.5# in the heat. Swapping to the 1.0 from the 1.32 gained 4# of launch boost at the same rpm and full boost comes on .5 second quicker.
