It's a B/W wheel. I don't think they deal with B/W.Contact Patrick, Donnie. If anyone would know it would be him. I bet he could come up with a trick wheel which would help the spool some.
The new T/C stator is 'in the mail'. Can't wait. :biggrin: The promise is at least 300 rpm more stall speed. That would put the new stall speed, on the nitrous, at 4100 rpm, at least. The boost transition point, on the nitrous is 3800 rpm. The turbo, with the nitrous assist, is generally building 1-2 psi of boost at this point. If the stall happens to increase to 4500 rpm,... hold onto your hats!
There's a promise of higher T/C efficiency on the top end also. I wonder what this thing looks like.
I'll have to think about the pics of the stator. It's someone elses design, and I don't know how widespread this new stator technology is. If it were my own, you know I'd share it.
The old stator that is in the T/C now is a simple fabricated steel stator. It is a stage V stator. This was as far as I could go with this stator design and the other components to get the highest stall out of this turbine/impeller combination. The fins are flat and bent to shape.So this isn't a stator from Chance?
It won't be very far different than what you have if your not having to change other internals around to compliment the new stator.
From what I gathered in talking with Marty, the new stator that's coming is new technology for them. Don't know when they started supplying these, but I think it's been pretty recent. They are steel or aluminum CNC machined stators. I would imagine that being CNC machined they have much more control over the whole shape of the foil. I'm sure it's not just a flat shape as what I've been using.
He was very confident that I would see a difference, and was very hesitant to change the turbine/impeller combination. We'll have to wait and see.
Marty understands the difficulty with my combination. As he put it, you're either a hero, or a zero with this turbo V6 stuff. He's not totally sure himself what I'm going to end up with. We're experimenting. Just my style. At least, he seems excited about this new technology and is willing to work with it. We'll find out next week.
The target is 1.8-1.9:1. I've thought more about it and I think I'll start off with 31/31 jets first, see how it works, and then lean it to 32/31 if things look right for it.Nice. So what a/f are you targeting with the big shot? And you're still just running the shot to spool it up, right?
TurboTR
