I'm the original owner of an '87 TR and have racked up 300,000 miles on the original motor, turbo, etc.. (no, the trans did not make it..) I still use the car as my daily driver from spring till winter. However, with the miles racking up and oil leaks not improving I'd like to do the motor before something goes amiss.
Unless I can be persuaded otherwise my preference is to put the original motor in storage and install a crate long-block from Jaspers or other source. Primary reasons are..
1. less downtime (weekend project)
2. will allow me the time to plan and save$$ for the buildup of the original short/longblock.
3. I can get a Japser long-block at cost, approx $2000. Core charge is $185 which I'll keep. Cost is a concern right now since most of my $$$ goes to feed my twin boys.
Comments, suggestions, experiences? I did verify with a friend who lives in Jasper, IN that the GN motors are built "off-line" by hand in their race shop using GN cores (turbo heads, block, etc...)
Was concerned that they may use a Hyperectic piston but was told by jasper rep that they are a reproduction of the deep skirt stock cast piston.
Anyways, stock is not bad in my book if I got 300k out of it and can still run in the low 13's @16lbs boost.
Appreciate any inights. sorry for the long post.
