three turbos
NUNLKME
- Oct 17, 2010
Sounds like good times to me!!! Are you trying to say this would be the expression on my face>
do you run straight meth or mix w/ water?
SignUp Now!Sounds like good times to me!!! Are you trying to say this would be the expression on my face>do you run straight meth or mix w/ water?
What do you plan to do with the car? Race/cruise/grudge?
Did you read this?
http://www.turbobuick.com/forums/alcohol-nitrous-propane-tech/147348-tuning-alkycontrol-kit.html
Alky is a great investment.
Just trying to help. Are you making progress with your car? I have seen you going through a few issues yourself. Your hybrid is just like the rest of the LC2 cars here. Takes time patience and logical evaluation before you make changes or buy things for it. I check the board frequently but pm or email me if you have any question I might be able to help you with. That goes for anyone. :biggrin:
Chain should be done alky kit or notDoes anyone see a concern in putting this kit on a car with 107,000 miles all original motor never opened up except to change valve springs?
No issues with mileage. 107 is nothing![]()
Anybody have a specific grind cam that works well with the alky set up that they are currently running?
Comp makes some good off the shelf stuff for our cars If it's in the budget get both, ported heads and cam But if u can only get one I'd keep stock cam n buy a set of ported heads. Even stock heads still, as long as they r ported u should gain more with them n the stock cam then stock heads and a roller cam.
Yes, I definitley plan to go roller so i dont have to worry about oil additives plus the performance gain,any particular brand?
