Alky overflow bottle install help
fatride
Senior Member
Need some ideas on insatlling the radiator overflow tank. By the way it's Razors kit. The 2 black straps will not hold the bottle. Anybody insatll it in a differet place other than on the side of the fan??
Thanks guys:)
Between the battery and core support. Cap facing the radiator. Yes it fits there ;)
I went to Autozone and bought a universal overflow tank. its bigger than the one that comes in the kit, yet its shorter and more square.
I put it on the drivers side where the stock air cleaner was.
fits perfectly.
mounted mine by the fan
thenI went dual fans so that required moving it again so it ended up sideways above the passenger fan.
now I have it mounted upright facing forward on the passenger side lower inner fender flap down by the alky pump
had to drill two small holes but its very stealthy there
if you need a pic i should have a few
Throw that one in the spare parts bin, go to a wrecker and get one out of a late eighties or early ninties ford festiva (cost $2). Fits on the drivers side between the plastic inner fender and the fuel evap canister( if it hasn,t been moved yet) . Use the supplied clear hose from the replacement one, mine was the perfect length . You need to make a small bracket to make the bolt holes line up, but pretty simple. Looks like it was made to go there by the factory. Took me a day at the wreckers and about 100 different cars to find this one, but couldn,t stand the cheesy look of that hang on one. If anyone wants pics, just let me know
