Alky ?
kraus
I have a 87 Gn with mods in sig.I am looking to add ALKY want to install easiest PrOGRESSIVE kit that works.Also I want it to be a kind of a stealthy kit as far as stock look if you know what I mean.I don't want to buy a 1000 things to make it work.I know I have to change my chip to work with it which I will be sending in soon. I am going to be ordering a cam made for with my setup and putting on a set of gn1 aluminums with 75 tb and prorted elbow and intake to complete it.Of course a lil bottom end support to.
But what kit is the best bang for the buck and hassle free? Smc,Razor, Devils own etc if you got pics of setups feel free to share thanks.
do a search....it gets beat to death a LOT !! for a simple answer "Razor's" :eek:
Ive read alot of the post on it and seems like everybody has own like to either.So you say razor why?
Grumpy is running 9's with Razors Alkycontrol. 'Nough said!
Yeah and I kinda of like it also....;) I have only been dealing with these cars for 13 years now and its the best bang for your buck that you can get. Julio will not let u down.
I bought smc works gerat and is simple to install and looks clean when installed!!! u cant go wrong I am not knocking any body else iam shure the other kits work well also
I'm running an SMC but switching to a Razor kit. In my opinion the SMC pump is not really meant for 10 sec times. It's just not that big. The SMC setup is a really nice kit and I would rate it OK to the mid-low 11's.
I have run 10.7@125 with the SMC at 70 PSI pump pressure and dual nozzles - tickling the knock sensor 0.5 degrees. With the Razor kit I'm looking to acheive +150PSI pump pressure with dual nozzles and really let the juice flow.
This is the kind of info i want to see. I understand Grumpy is Super Fast Buick Car GOD but every car is different.Nothing against Grumpy or his car's,I am just trying to make the best choice right away instead of three wrong ones...
simple to use .. I am the king of simple :p there are other's out where you can watch the spray of the nozzle on your laptop :eek: more do dads than a new Lincoln town car :biggrin: Razors..simple..can't beat his service and it works :p
Do you have any pics of the setup on your car just want to see where some off the stuff is mounted.If you don't want to I understand.
+1 for Razors.
Simple install, controls easy to hide for the stealthy look. My controller is in my glovebox. It just plain works right out of the box. I have had no experience with other kits so I can't speak for them. Razor is a member here and is very available if you have questions before or after the sale. In my opinion there was no choice to make.
Bryan
dual nozzle... the controller goes on the side of the radio pod.. Ill get a pic tomorrow for ya :cool:
I switched to Razor's PAC and have had the bedest customer service and satisfaction I could ask for. Great unit and very reliable. 26# and pushing.
I have a very basic bolt on set up and run pretty well.
Julio is very cool and will answer any question.
looks pretty simple Grumpy.Would you recommend dual or single nozzle.Reason I ask is one more reliable then the other and such?
your set up a sigle nozzle would be fine,,,,I have razor and any question I have is answered,,,,,,,except my e-mail about an upcoming event:) :wink:
here is the controller.. you can put it anywhere really :cool:
