....... Who do I contact for ordering the powerlogger, TT wideband chip, and an 87 ECM/MAF combo all at once? I guess I need an IAT sensor and wiring as well. I want it to be plug and play compatible so I can swap it back to the old ECM if necessary, but my MAF just went out and its not as easy to find the early units as the 86-87 style.
Good question;
You can get the PL, chip and MAF from TT.
(I think he still carries the MAF). You will need the translator to have the MAF work correctly.
There is another option: SD (Speed Density) which eliminates the MAF and relies on MAP, MAT, and WB, along with other factors (LV, TPS, Speed, RPM) to get the correct fueling.
The IAT/MAT set-up can be had from CaspersElectronics
....... Also a worthwhile question, once the "learning" is performed by the ECM with regards to part throttle and full throttle operation and the tune is perfected based on the chosen AFR, is there a way that we can "lock" these tuning parameters in the chip so as to keep it there? I realize differences in altitude, temperature, baro pressure, etc all play a role in the day to day variations that exist as tuning issues and that leaving it in WB tracking mode may serve to be better in the long run. However I also have had WB sensors fail on a whim and dont want to be without a car that runs correctly if such a thing happens. Id rather have a saved prom calibration from a few days prior that works correctly while I wait on my new wideband sensor should a failure occur. Thanks!
Another GREAT question. :wink:
Part of racing is making sure things work.
No different than a fuel pump or valve spring that can fail at any time.
Having said that . . .
There are some good reasons you want the WB control.
Temp fluctuation;
There could be a 15% fuel difference from 80-30F.
If you go to 30F, the 15% fueling difference could do some damage.
Winter vs summer blend;
Even if everything worked fine, you could potentially have a tuning issue.
You can tune around the WB, but will never have the resolution and control without it, with the gas differences.
Differences in humidity and baro.
These are the things that change that decrease the state of the tune.
The WB control takes that headache out!
Other variables: Filter, pump, etc
Filters change over time i.e. "They get dirty". That is just what they are designed to do.
With a dirty filter comes a potential other issue; Fuel flow
Same with a weakening pump.
Yes, you should monitor fuel pressure, but again, it the pump gets a little weak on a run, you can do a lot of damage QUICK!
Now, the WB control will not eliminate the issue, and this feature should never be used to cover up this kind of thing, but it will react faster than your foot, and just "may" save the day.
Having said all that . . .
In the same chip, you can get the BLM number to "99" and it will no longer be "closed loop" and rely on the WB.
How cool is that?
