Im getting my Turbobird ready for drag season again. I just ordered one of Razors kits:biggrin: and some other goodies!! My current mods have ran a best time of 12.20@112mph on a 1.75 60'(ran with mix of 93 & 110 gas)
My Current Combo:
90 Firebird w/ 3.8L swap
3500lbs w/ driver
3.8L 109 block (bored .030")
TRW Forged pistons on stock crank and rods
Stock heads, cleaned up and good springs
Erson 208/208 Flat tappet Cam
Stock Lower plenum
Kenne Bell 70mm upper intake and throttle body combo
Stock Headers(cracked drivers side)
TE44 Turbo(leaking @ header)
Stock Intercooler w/ no shroud
3" Maf pipe w/ K&N Filter
3" DP w/ external HKS wastegate
50# injectors
Turbotweak 93 street chip set to 18/20 degrees timing and 20psi boost
Scanmaster 2.1
TH400 junkyard tranny w/ 3200 Stall TC
GM 10 bolt w/ 3.23 posi
27-10.5-15 Hoosier slicks and 26-4.5-15 skinnies on Weld ProStars
Stock Carter/Napa Fuel Pump w/ hotwire kit installed
So far, Ive ordered;
Razors AlkyControl
RJC powerplate for KB Plenum
Kirban Performance High Flow Fuel pump
Duttweiller neck for stock IC
All Copper Exhaust gaskets(tired of leaks)
New Motor mounts
Plan to order:
F-Body Subframe Connectors
Line Lock
Airbag for rear springs
TurboTweak 93/94 Alky Chip
Sheet metal to make custom intercooler scoop
Anyways, what 1/4 mile times and Horsepower/Torque numbers do you guys predict in my future??? And what boost levels would you guys typically run? Assuming I got a problem free engine/transmission lol??? Thanks for the insight and thanks for looking!!!
Chris
My Current Combo:
3500lbs w/ driver
Stock Lower plenum
50# injectors
Scanmaster 2.1
Razors AlkyControl
New Motor mounts
Plan to order:
Line Lock
Chris
