Old setup - girdled 109, port work on stock irons, 208 comp cams, THDP, Hooker exhaust w/dump, PTE44, stock intercooler with dutt neck, TT chip, 43psi line off, (v5.5 93 pump, maxed out WOT fuel and +1* of timing in both 1/2 and 3/4), blue top 42.5's, hotwired 340, Art carr tranny (5200rpm shifts) and re-stalled D5 converter, Nitto 275 DR's on stock rims.
My best time then was 12.29@112 (2.0 60ft) back in January on about a 55 degree night.
I finally got to the track last night with the following changes - CPT66BB, Cottons FMIC, 60lb inj, TT alky chip, Alkycontrol dual nozzle kit, fully built transmission (5700-5800 shifts), and a PTC 9.5" 3200 stall, dual air bags with 5psi in drivers and 20psi in passenger.
The first pass was on 19psi and I went 12.5@107 with a 1.80 60ft
Second pass was slightly turned up at 20psi and went mid 12's again @108
The third pass I turned it up to 24psi and only went 12.3@110 with a 1.85 60ft.
I had to let off slightly on the last two passes in 1st gear due to some wheel hop but I thought this setup was going to run a hell of a lot faster than this. All of the passes had 0 degrees of knock and mid 700's O2.
The only thing I can think of is that the weather played a factor with high humidity and about 85 degrees compared to January. The other thing on my mind is that with a dual nozzle kit and a voltage booster it may be drowning it out with alky. But other than that I wasn't too impressed with the outing with all the money in this thing
