.035" 308 filler on the tubes and inside of the flanges. The outside of the flanges is silicone bronze.
The machine is set for 70 amps for welding the tubes, but I throttle the pedal a lot. I probably weld closer to 60 amps
Red 1/16" tungsten
#6 gas lense with torch argon at 15 cfh, purge argon at 5 cfh
I don't use solar flux. If you have two bottles and two flow meters, purging is much easier.
I don't wear any breathing protection and I've never had any issues.
Red 1/16" tungsten
