SignUp Now!Scott, I thought I'ld bring this back to see if you are still running that battery and how the results are.200 amp, running at 14.8 - 15.0 volts. There is a plug on the top for their equalizer but I haven't done anything yet. Also, no long term results, I bought the battery as an experiment.
900+ cranking amps. 10 lbs
Not if you turn the battery around. LolPosts are in the wrong corners for our cars.
Lithium?? Not in a battery, but I suspect some members use it for "personal reasons"..Especially after owning a Buick V-sicks, for some time.![]()
