Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
Good to hear, thanks for relying.
SignUp Now!Hey MurphsterAs a follow up from me... I am still using my same Deka ETX 30L battery that I have had since Feb 2015. Small 22lb battery that I keep on a battery tender regularly. Still a good cheap option to Lithium batteries for a little over $100.
Hey Murphster
Is this battery a direct bolt on , with the exception of holding it down and battery cables connectors. For example, if the fan is running at the track and I have my lap top plugged in , will the battery manage or will it die quickly? Any negative effects to the alternator? Regular battery tender for a car battery works ?
hmmmmm... From the info on that battery . wonder why ."
*Please note that the DEKA ETX series is NOT intended for use in any automotive vehicles."
Have a pn or model number for this?Antigravity is what I have. Weighs 5 lbs with 720 cranking amps which is about 150 more CCA's then the stock battery. No trickle charge either. Starts up fine. Was 28 degrees out the other day and started like it was mid summer.
also they don't like being stored for long periods of time at full charge. Will last longer around 50% charge if car is not being used. Not worth it to me.They require some more care. Lithium batteries don't like being cold, and they don't like being run dead flat.
So, keep the car in a garage. You could also get a battery warmer. If it's below freezing and it's sat for awhile and you don't have a heater, turn the headlights on for a bit to let the battery warm itself back up on a lower current before trying to use it to start the car.
And get a battery with undervoltage protection that'll cut the battery off if the charge gets too low. If a Lithium battery goes flat, it's done for.
On the plus side, a properly cared for Lithium Ion battery will last 5000-6000 charge cycles. That's like 10-15 years for a daily driven car.
