Hello, I am still under construction on my installation of the AFX package. I have purchased most all the parts and have been working on it slowly. I am running MOOG 5658 springs, ATS tall spindle with C5 hub, ACDelco drilled and slotted rotors, Z06 Calipers, adjustable SPC uppers, stiock LCA's with Del-Alum bushings. I still havent started to work on the lowers yet because I will be making a template for inserts to weld into the bottom of the arm. This really doest need to be done becuase the stock arms are actually very good the way they are. My biggest problem with aftermarket LCAs is that they usually run Polly bushings. I will not run polly bushings on any of my suspension pieces unless I absolutely have to. So instead of spending $400 on LCAs that come with polly bushings, I'll spend $4 for spray paint, $23 for a new ball joint, and $20 for Del-Alum bushings for each side and be done with it.
