1KWIKSIX
- Sep 29, 2007
I'm installing a new Wildwood MC with adjustable proportioning valve mounted to the side and am about to plumb up new brake lines.
Wondering if the coiled / squiggly flex joint / circle portion located on the stock brake lines at this area are required? What is the purpose of these.
New body bushings have been installed so there should be little to no movement between the body and frame.
Don't have a lot of room on the inner fender area where all this will be located as I've got to install some wildwood residual pressure valves in line and would prefer not to also have the short coiled section of brake line located here too.
Any comments or suggestions would be appreciated.
thx
dave
thx
dave
