ArizonaGN Aluminium Heads
pitch black
I'll just leave these here ;)
So beautiful! !! What would a set of heads like this set you back?
Depends if you want out of the box, port work, what springs, valves, etc.
Call nick I'm sure he will discuss your needs and get you up with something nice that will fit your needs and your budget.
those are TA heads , that Nick customizes , and does his magic on them,
so they are a "quality" set of heads!
Damn those are nice, I wouldn't expect anything less with that name on them:) Tell us more
I'm sure nick has flow numbers on these heads but remeber flow numbers aren't the end all be all on how something is or isn't going to preform. I could be wrong but he not only uses the flow bench but lots of track passes to figure out what works and what doesn't work on these heads.
