Auto-X valve covers
scot w.
GNSperformance.com
This should be a good solution to oil pouring out of the factory breathers when I auto-x the car....
The breather tubes are centered in between the rocker arms to keep the oil sling down and keep the breathers working properly by not getting drenched with oil.
Before under a hard left hand tunes the car was under so much g-force that oil would literally pour out of that little front breather and run down my a-arms! Not anymore! :)
you could go full "racecar" and tie the two valve covers together with a tube that has the breathers in the middle, maybe on either side of the throttle body..
