 - Feb 18, 2006
Bob will check and/or replace the chip. As you know he's a great guy. Just put a few bux in the box so he can get a cheeseburger. Those are his favorite. :biggrin:
SignUp Now!Check your positive battery cable, specifically the orange MEM wire that's fuselinked to the single weatherpack connector.
That's what was wrong with mine. The orange wire right behind the battery.
Figured I's post and update. Spent the afternoon replacing battery cables.,removing and cleaning all engine grounds. A waist of timestill does the same thing intermitantly of course. I am starting to agree with Rick. A6 circuit 439 feeds the ecm/esc/maf/CCCI ignition. On the power logger I still have a wideand reading,map reading(boost) when everything else drops out. They are not powered from that fuse..ecm/sol..
I am starting to wonder,I have to taps into the fuse block at IGN1 one for wideband another for alky kit. Maybe I have that circuit overloaded? I have the scanmaster at ignition 3.
Tommorrow I will mess with the fuse block and the ignition switch. Starting to lean towards the ignition switch.
Steve,
Does it seem to happen right about the time alky comes on?
For the hell of it, run a hot wire from the back of the alt into the car. Unplug the alky from the fuse panel and tie to the hot wire.
See if that makes any difference.
RL
