scot w.
GNSperformance.com
- Feb 19, 2005
I just want to cap this Brake install off with a few more things that people might want to know..
First of all I want people to know that I have the Vacuum conversion set up from a 1986 Monte Carlo SS which has a stock bore size of 15/16" or 24mm or 34mm depending on the part number.. BAER recommends a 15/16" bore for the Track4 / SS4 set up so either of those will work very well...Needless to say I didn't need a different master cylinder to make this system work. I took the car out for a spin tonight for a good 1hr drive and these brakes are CRAZY! I swear I can stop on a dime!!!
To bleed the brakes I used a hand held/pump "Mighty vac" bleeder system and here are a few things that I found that might help others while using this type of vacuum bleeder.
1). Make sure ALL of the hose connections on the (Vac pump) are sealed (I used a small safety wire) to make sure all hose connections were sealed tight..
2). Before adding new fluid to the reservoir, take all of the bleeder fittings out of the calipers one at a time and wrap the threads with Teflon tape, Note: This is NOT meant for sealing proposes but to keep air from escaping around the threads when bleeding with the Vac bleeder. The goal is to have a perfectly sealed system. (If your bleeding the regular way via Peddle and another person disregard this).
3). Open the bleeder Farthest from the master cylinder and let sit until fluid starts to come out. This will speed up the process of bleeding.
4). Once fluid starts to come out of bleeder on it's own, Shut off, attach the Vac bleeder hose to the fitting, Pump the handle until it shows 20in vac and open the bleeder. Repeat until no bubbles are visible...Repeat with the rest of the wheels and DO NOT let the reservoir go empty!!!
5). This took a short time all by my self today and after a few pumps of the brake peddle, I ended up with a perfect peddle that feels better than when I started. I took the car for it's maiden voyage tonight and the brakes & peddle are PERFECT and this car will stop on a "Hair" !!!! It's Crazy!!!
Now it's time for BAER's Rotor & Pad bedding process and we should be ready for the track!
Scot W.
Scot W.
